    • On the Floor
NewTek AC-LVDTs serve as reliable alternatives to magnetostrictive sensors in power generation applications
By Heather Hall | June 29, 2023
NewTek AC-operated LVDT Position Sensors often serve as a more reliable, precise, and cost-effective alternative to magnetostrictive linear position sensors in the monitoring and control of valves in power generation and hydroelectrical stations. Because power generation environments can reach temperatures of 250° C (475° F), magnetostrictive technology might fail or become inaccurate over time. While very accurate in benign applications, most magnetostrictive sensors cannot operate over 85° C as electronics must be placed very close to the “wand”.
With electronics separated from the LVDT coils, NewTek’s AC-operated linear position sensors continuously operate in power generation stations without failure at high temperatures. While the LVDT sensor remains in a harsher environment, NewTek’s NTC-6000 LVDT Signal Conditioner (which excites the AC-operated LVDT and provides a variety of output options for use in PLCS and other control systems) operates in a less innocuous environment. By using a low operating frequency range between 2 kHz to 4 kHz, the LVDT and signal conditioning are separable by 100 ft or higher.
With attributes such as frictionless measurement, infinite mechanical life, excellent repeatability, and good temperature stability over extended temperature ranges, NewTek AC-operated LVDT position sensors are a suitable linear position technology for valve applications, while providing both short and long-stroke measurements, typically from 4 in. to 20 in. (4 cm to 50 cm) or more.
NewTek LVDT Position Sensors also measure movements as small as a few millionths of an inch, which is essential for some power plants that need to know the exact degree to which a valve is opened or closed. For a medium-sized plant, a 2% efficiency improvement could translate into a million dollars in fuel savings.
Other applications with fluctuating exposures to high temperatures, such as thermal chambers, steam turbines, and chemical plants, can benefit from using NewTek’s AC-operated LVDTs for different position measurement applications.
NewTek
www.newteksensors.com
Filed Under: Sensor Tips
Tagged With: newteksensorsolutions, newtek
  • Five trends in automation for the second half of 2026
  • Robot blowback in Korea and China growth slows
    • On the Floor
