Opto 22’s HART SNAP analog I/O modules
By Frank Tobe | September 26, 2014
Industrial automation manufacturer Opto 22 has released the SNAP-AIMA-iH and SNAP-AOA-23-iH two-channel analog input and output modules, each with HART communications. Both SNAP I/O modules use the HART communications protocol to extract status, diagnostics, and other information from smart devices such as field-mounted process transmitters and analyzers. This information can be used by the automation system and/or the asset management system to increase uptime, improve productivity and enhance safety.
HART is the most widely used digital communications protocol in process automation, and the HART Communication Foundation (www.hartcomm.org) is continually updating the protocol.
The SNAP-AIMA-iH analog input module has two isolated 4-20 mA input channels, and the SNAP-AOA-23-iH output module has two isolated 4-20 mA output channels. Each channel features an integrated HART modem that allows the channel to communicate digitally with the HART FSK (frequency-shift keying) signal imposed on the 4-20 mA current loop, enabling communication with the target smart device.
Each channel is a HART master device when used with Opto 22 programmable automation controllers (PACs), and can communicate with other HART current loop devices in either point-to-point or multidrop configurations.
The SNAP-AIMA-iH analog input module is categorized by the HART protocol as a current input connection type, which means that the module is a low-impedance device. The SNAP-AOA-23-iH analog output module is categorized by the HART protocol as a current output device, which means that each channel can provide the required loop current and is a high-impedance device.
Each module includes LED indicators to provide status information, such as HART channel operation, communication errors, or zero loop current or voltage reading.
Both analog modules are transformer isolated as well as optically isolated from all other modules and from the I/O processor. Transformer isolation prevents ground loop currents from flowing between field devices and causing noise that produces erroneous readings. Ground loop currents are caused when two grounded field devices share a connection, and the ground potential at each device is different. Transformer isolation provides 1500 volts of transient (1500 V for 1 s) protection from industrial field signals.
In addition, all channels are isolated from each other. Channel-to-channel isolation provides complete freedom from ground-loop problems, even on grounded devices connected to channels on the same module.
SNAP-AIMA-iH and SNAP-AOA-23-iH modules are used with Opto 22’s SNAP PAC System, which includes programmable automation controllers (PACs), Ethernet-based I/O systems, and PAC Project automation software. All HART commands for wired devices including universal, common practice, and device-specific commands are available for these modules in PAC Control programming software (version 9.4 and higher), facilitating quick integration with HART smart devices.
Opto-22Process engineers can incorporate data from HART devices into their control applications just as they do the analog, digital, and serial I/O signals received from other SNAP I/O modules installed on the I/O rack. And using Opto 22’s groov mobile operator interface, HART device and all other control system data can be displayed quickly and simply on any mobile device.
The modules can also be used with other process controllers. Opto 22 offers the SNAP PAC .NET HART developer toolkit so a user can easily integrate the HART SNAP I/O modules into an existing application.
Opto 22
www.opto22.com
Filed Under: I/O modules, MOTION CONTROL
Tagged With: opto22
