Position Detection Prototype Kit from Cal Sensors
By Patrick Curran | February 21, 2014
Cal Sensors announces the launch of a new Position Detection Prototype Kit, a plug-and-play tool designed to dramatically accelerate prototyping and product development for position or flash detection instruments. Applying PbS and PbSe detector technologies, the Position Detection Prototype Kit shortens time-to-market by allowing engineers to focus on the challenges of their instrument’s design, quickly validating detector viability and providing proof of concept.
Building upon the industry-leading speed and sensitivity of the PbS and PbSe detector technologies, the kit provides enhanced field of view and new tools for signal characterization and analysis.
Prototype Kit Components & Applications
The kit consists of two lead salt detectors that provide market-leading sensitivity of 1.5E10 Jones across the 1.0 to 5.5 µm infrared region. The detectors are positioned at 90° angles to each other to maximize the overlapping fields of view and optimize the triangulation of the position of the target infrared signal.
The prototype kit contains all the circuitry and integrated electronics necessary to drive the detectors, as well as the supporting software. Both hardware and software are highly customizable to meet the varied requirements of different applications.
The new Position Detection Prototype Kit is well-suited for the development of position and flash detection instruments. This kit can potentially capture the infrared signals from fires or flames, hotspots (from overheating equipment) or muzzle flashes up to 150 meters away.
Key Features
Position Detection
Incident location is radially displayed in terms of range and position, similar to a radar screen. The high response speed of the detectors (up to 10x higher than alternative optical technologies) facilitate an almost instantaneous capture of an infrared radiation event.
Signal Characterization
In addition to repeatable, fast detection of incident location, the Position Detection Prototype Kit’s software is designed to provide valuable information on the characteristics of the infrared radiation. Data on signal amplitude, duration and peak location are all captured for subsequent analysis. This provides the means to potentially differentiate and identify different radiation sources. For example, different firearms can be identified based on the signal characteristics of their muzzle flash.
Enhanced Field of View
The standard Position Detection Prototype Kit provides over 20% greater field of view than an individual detector. Multiple systems can be combined to expand the field of view both horizontally or vertically. For example, two system mounted on a horizontal plane can cover over 210°. Up to four systems can be combined to maximize the field of view for a specific application.
Cal Sensors, an ITW company
www.calsensors.com
Sensor Tips
Filed Under: Sensor Tips
Tagged With: calsensors
What sensors are used in AR/VR systems?
What’s an acoustic leak detector?
How can sensors help cleanup waterways?
How do sensors improve wind turbine performance?
