Effective immediately, RST customers can easily find the right pressure equalization device for their application to minimize, for example, the generation of harmful condensate in electronics housings.
Because pressure equalization elements must meet a wide range of requirements, RST has significantly expanded its product range in recent years, so it can offer the right solution for most any application. And the new pressure equalization calculator, which is based on a physical mathematical formula, provides extra support. The online tool is available free of charge at www.ventcalculator.com.
With the pressure equalization calculator, you can easily determine the precise air flow needed to keep your particular system functioning. You enter the enclosure volume, the start and end temperatures, the process time and the operating pressure differential, and the calculator shows you how many components should be installed under the defined conditions. The complete list of available pressure equalization devices shown on the same page can be filtered by type, material and connection thread.
RST
Filed Under: Green engineering • renewable energy • sustainability
