This low cost, constant current LED driver is both compact and versatile. With a voltage range of 90-295 VAC, the RACD07 is suitable for worldwide use. The 7 W modules are available with constant current outputs of 350, 500, or 700 mA. For applications with limited space the RACD07 simplifies installation with both input and output lead wires integrated into a single side including the mounting bracket. The driver is IP67 rated and can be used in dry or damp areas such as bathrooms or even outdoors. Features include:
- Input to output isolation voltage of 3750 VAC for protection against short circuit and overload.
- Designed for a long lifetime (MTBF>200,000 hours).
- Certified to EN61347, EN61000-3-2, as well as EN5015 Class C, with UL certification pending.
For more information, visit www.recom-power.com.
