Rotron ‚“EN‚†regenerative blowers are designed for a wide range of environmental remediation
applications. The explosion-proof motors are UL and CSA approved for Class 1, Group D and F&G atmospheres for safe operation in the harshest environments. They employ regenerative air technology to develop proper air pressures and vacuums without the higher energy and maintenance costs associated with larger multi-stage or positive air-displacement blowers and compressors.
Features include heavy-duty cast aluminum manifold; spark-resistant and vacuum-impregnated housing, cover, impeller, muffler tower, and manifold; PTFE lip seal in a stainless steel case for leakage containment to 25 cc/min or less, sealed blower assembly for minimum leakage and sealed motor bearings for up to 25,000 hours of service life. The blowers can achieve maximum flows up to 920 scfm; pressures up to 114 IWG; and vacuums up to 168 IWG, depending on blower style. Voltages range from 115 Vac.
AMETEK Technical & Industrial Products
www.ametektechnicalproducts.com
Filed Under: Blowers, Pneumatic equipment + components, MECHANICAL POWER TRANSMISSION
