    • On the Floor
Rexnord XTSRLS Thomas disc couplings
By Mike Santora | November 10, 2020
rexnord-XTSRLS71-C-disc-couplingThomas XTSRLS couplings are full-floating shaft couplings designed for applications with relatively long distances between connected equipment, either horizontally or vertically. XTSRLS couplings are a suitable choice when shaft spacing exceeds the maximum length of standard fully machined spacer designs (XTSR52/ XTSR71). Common applications include vertical pumps, fans & blowers, compressors, and paper machines.
XTSRLS52: Welded steel spacer with optional adapter for expanded bore capacity.
XTSRLS71: Welded steel spacer with standard adapters for easier installation and greater bore capacity.
XTSRLS71-C: Composite-material center spacer for lower overall weight versus all-steel models, enabling higher speeds and extended span distances.
Rexnord
www.rexnord.com
Filed Under: Disk, Couplings
Tagged With: Rexnord
  • Siemens aims for 80 percent automation in German plant
  • Humanoids building humanoids, and new robots for agriculture equipment in Kansas
  • Amazon takes on another industry: robotics
    • On the Floor
