Rubber spacer disks vulcanized, with steel plate from JW Winco
By Mike Santora | February 12, 2019
JW Winco-GN-438-Vulcanized-Rubber-Spacer-Disks-with-a-Steel-PlateJW Winco, Inc., A Ganter Company, a supplier of standard industrial machine components, now has available, GN 438 Vulcanized Rubber Spacer Disks, with a Steel Plate.
The GN 438 rubber spacer disks provide a dampening and muffling function, protecting surfaces from damage. “By stacking several spacer disks on each other, the spring rate of the combined disks can be increased, which opens up new possibilities for use,” said John Winkler, CEO, Office of the President at JW Winco.
When used as a foot disk, type A, is attached using screws and can be installed on small machines, systems or devices. “Bear in mind the maximum height of the screw head,” Winkler said. “Alternatively, after the protective film has been removed, the type B version can be adhered to all suitable and clean surfaces by means of the adhesive pad.”
The steel disk plate is zinc plated, with a blue passivated finish, while the black rubber underlay is vulcanized, and is temperature resistant up to 248 °F (120 °C).
JW Winco is a manufacturer/distributor of inch and metric standard parts. JW Winco offers a selection of plastic, steel and stainless steel adjustable levers, cabinet U-handles, hinges and locking mechanisms, revolving and retractable handles, hand wheels, hand cranks, tube connection and conveyor components, construction tubing, shock absorption mounts, leveling mounts, hand knobs, spring, ball and indexing plungers, jig, fixture and fastening components, retaining magnet assemblies, toggle clamps, casters and wheels, universal joints, oil sight glasses, and metric tools for the industrial and commercial equipment industries.
JW Winco
www.jwwinco.com
Filed Under: Fastening + joining, NEWS • PROFILES • EDITORIALS, MOTION CONTROL
Tagged With: jwwinco
