The FMBC EP double-stage filter family for three-phase systems sits in a compact package, ideally suited for today’s space constrained machine and industrial plant construction. Versions with high nominal voltages are particularly suited for a wide field of applications.
Space is scarce in control cabinets for three-phase industrial applications. SCHURTER
has addressed this problem with downsizing its EMC filter range, which is much more compact than previous generations. The new, almost cuboidal design, makes optimum use of the space in the housing. The double-stage filter built with the highest quality components (generously sized film capacitors, chokes with highly permeable cores), provides exceptional broadband filter attenuation.
The double-stage filter family is therefore also appropriate for applications with particularly high EMC emissions, as is frequently encountered in machine operations. Typical applications include automatic production, motor drives and industrial plant machinery. These powerful filters are also the first choice for modern frequency inverters for motor control.
The FMBC EP series features screw terminals for absolutely safe wiring. A metal flange provides an excellent earth connection when screwed to the chassis. Standard types can be used over a wide temperature range from -40 to 100°C. The filters are designed for currents from 16 A to 230 A at an ambient temperature of 50°C. They have both ENEC and cURus approval and are recommended for applications up to 520 Vac or even 760 Vac. The standard versions are designed for industrial applications with leakage currents below 4 mA. Special variations, rated with below 1 mA leakage current, are available for applications where minimizing leakage current is critical.
Pricing starts around $89.00 each for 50-piece quantities. For sales and product information, contact Cora Umlauf at (800) 848 -2600 or by email at [email protected].
SCHURTER Inc., 447 Aviation Blvd., Santa Rosa, CA 95403, www.schurter.com
Filed Under: Filters (electrical) EMI • COTS • noise filters • shielding, MOTION CONTROL, ELECTRONICS • ELECTRICAL
