Self-adjusting rotatable die crimping tool
By News Staff | March 22, 2019
The DN-FE-16T crimping tool has a rotatable die and a trapezoidal crimp profile. The crimper is self-adjusting for use with insulated and non-insulated wire ferrules in sizes from 26 to 8 AWG. The crimp head is rotatable to accommodate crimping from the side or from the front.
This new crimper is identical to AutomationDirect’s two existing self-adjusting crimpers, other than having the rotatable die and trapezoidal crimp profile. The crimpers are lightweight, compact and comfortable for crimping a wide range of insulated and non-insulated ferrules, crimping terminals, and connectors.
DN-FE series crimpers feature controlled-cycle ratchet action (with emergency release) to ensure crimps are completed according to specification every time. The crimpers are well balanced to avoid slipping and provide a low handle force for larger ferrule sizes. The compact, light-weight design provides easy access within confined spaces; a non-slip grip pad allows applying pressure against a surface for more crimp force.
AutomationDirect
www.automationdirect.com/wire-crimper
Filed Under: MOTION CONTROL
Tagged With: automationdirect
