TDK Corporation announces market availability of the InvenSense SmartBug 2.0, an all-in-one multi-sensor wireless solution with new features for consumer and IoT applications. SmartBug 2.0 is a smart remote data-collection module for IoT, developed after the success of the original SmartBug in 2019. The SmartBug 2.0 is available in two versions – a standard version and a machine learning version allowing customers and partners to evaluate TDK sensor performance under different use cases or to use it as a wireless data collector/tester with TDK machine learning software. Customers can switch between the two flavors through a firmware update. In addition, existing expansion boards offering Wi-Fi, SD card, and ultrasonic sensor support will work with SmartBug 2.0.
A key attribute of the SmartBug 2.0 is the replacement of the ICM-42688-P IMU with ICM-45686-S, the latest BalancedGyro™ IMU and the world’s lowest power IMU (220 µA @ 50 Hz 6-Axis) from TDK. BalancedGyro™ technology enables developers to collect high-quality IMU data for a longer period of time due to the 3x battery life. The new IMU also provides premium temperature stability and vibration rejection, making SmartBug 2.0 useful for products such as AR glasses, VR, OIS, drones, MR, TWS, and robotics for prototyping, data collection, and machine learning-based algorithm development.
Key features and advantages of SmartBug 2.0
- Machine learning: SmartBug 2.0’s key feature is the introduction of machine learning (ML) capabilities. Developers, ODMs, OEMs, and product developers can now use SmartBug 2.0 along with the sensor inference framework (SIF) by TDK to build machine learning solutions for the ICM-45686-S IMU. SIF is an all-in-one comprehensive software by TDK that enables users to collect IMU sensor data, select custom features, build ML models, test performance, deploy, and run those models on the ICM-456xy IMU through the SmartBug 2.0. Examples include algorithms such as exercise classification (squats, jumping jacks, lateral raises, or push-ups) and wrist gesture classification (fight, clench, shake, or still mode)
- Head tracking solution:SmartBug 2.0 adds support for VibeSense360™, TDK’s head tracking solution for TWS and AR applications. SmartBug 2.0 facilitates TWS and audio companies’ ability to collect raw sensor and head orientation data at the lowest power (280 µA at 50 Hz) and learn unique signatures about enabling spatial audio.
- Air motion solution: SmartBug 2.0 enhances TDK’s Air Motion solution by adding swipe gestures, remote orientation gestures, and accurate cursor tracking for smart TV remotes
- Data collection improvements: SmartBug 2.0 has updated streaming and logging parameters to enable longer duration streaming and logging of multi-sensor and algorithm data
Part Number | Supported Features | Software |
MD-45686-S | SmartBug 2.0 standard edition
Head tracking, Air Mouse, Sensor Fusion, Asset monitoring, APEX etc. |
SmartBug 2.0 GUI |
MD-45686-ML | SmartBug 2.0 Machine Learning edition
Builds, deploys, and tests TDK Machine Learning Algorithm |
SIF2 GUI
(Sensor Inference Framework) |
MD-42688-P-XB | Expansion board with Wi-Fi, SD card and Ultrasonic sensor | SmartBug 2.0 GUI |
TDK’s SmartBug 2.0 is available now for evaluation with mass availability across distribution at the end of August.
TDK will demonstrate the SmartBug 2.0 all-in-one multi-sensor wireless solution at the upcoming Sensors Converge 2023, at booth #992 at the Santa Clara Convention Center, June 20-23, 2023. TDK will present a full range of sensor system solutions targeted for applications across automotive, consumer, health, industrial, machine learning, robotics, and more across multiple TDK product brands: InvenSense, Micronas, Qeexo, and Trusted Positioning.
Glossary
- TWS: True wireless stereo
- AR: Augmented reality
- VR: Virtual reality
- MR: Mixed reality
- IMU: Inertial measurement unit
- IoT: Internet of Things
- ML: Machine learning
Key applications
- TWS
- Wearables
- AR/VR/MR glasses
Main features and benefits
- Supports ICM-45686-S IMU, the lowest power IMU from the BalanceGyro™ Family with on-chip sensor fusion
- Builds, deploys, and tests machine learning algorithms on ICM-45686-S IMU
- Supports evaluation of TDK’s VibeSense360 solution for TWS
- Out-of-the-box, one-size-fits-all solution
- Sensors: IMU, magnetometer, pressure, temperature, humidity and ultrasonic
- Arm Cortex M4 MCU
- Wireless connectivity: BLE and WIFI
- Rechargeable battery (290 mAh)
- USB interface
- Wireless multi-sensor and multi-algorithm data streaming and logging using a Win 10 GUI
- Autonomous data logging from multiple sensors on an SD card
- Embedded motion sensor events such as Tap, Tilt, Raise to Wake, Pedometer, Wake on Motion
- Dedicated sensor algorithm output data for multiple IoT applications
Filed Under: Sensor Tips
