TDK Corporation announces the expansion of the InvenSense SmartIndustrial™ sensor platform family with the introduction of the IIM-20670. The IIM-20670 features a robust monolithic 6-axis IMU, 3-axis accelerometer, and a 3-axis gyroscope, with proven shock robustness and capability to simultaneously measure all six axes with a current consumption below 10 mA under all operating conditions. With its support for an extended temperature range of -40 to 105Co, this new 6-axis IMU targets industrial applications that require extreme stability over temperature and great vibration immunity.
The IIM-20670 is calibrated over multiple temperature points and available in a compact QFN 4.5 x 4.5 x 1.1 mm3 form with wettable flanks that simplify inspection at the end of the assembly line. It also features programmable digital filters and a 10 MHz SPI interface where data integrity can be assessed by a CRC-based error-detecting code algorithm. The IIM-20670 contains an accelerometer thermal stability of 45 ug/C, an accelerometer bias repeatability of 1 mg, and a programmable output of 64G alongside with a tilt algorithm that outputs pitch and roll data over the full temperature range. These specifications allow the IIM-20670 to provide one of the most stable 6-axis tilt outputs in the industry making it ideal for applications that need robust, fast, and accurate tilt or stabilization performance such as 5G platform, Industrial tilt modules, industrial/agricultural drones, etc.
This thermal stable IMU for industrial applications delivers:
- Precise measurements enabled by highly stable IMU
- Support for extended temperature range (-40° to 105°C)
- 64g accelerometer output
- Best in class accelerometer bias offset & repeatability
- Strong vibration rectification performance
- A comprehensive development and evaluation platform along with necessary software to enable quick-to-market development of customer systems
TDK’s IIM-20670 platform is available now for evaluation and available through distribution partners worldwide by end of July 2023.
TDK will be demonstrating the IIM-20670 six axis IMU at the upcoming Sensors Converge 2023, booth #992 at the Santa Clara Convention Center, June 20-23, 2023. TDK will present a full range of sensor system solutions targeted for applications across automotive, consumer, health, industrial, machine learning, robotics, and more across multiple TDK product brands: InvenSense, Micronas, Qeexo, and Trusted Positioning. More information on TDK technologies and solutions can be found at here.
Glossary
- MEMS: Micro Electrical Mechanical Systems
- IoT: Internet of Things
- 6-Axis: 3-Axis Gyroscope + 3-Axis Accelerometer
- IMU: Inertial Measurement Unit
Key applications
- Navigation
- Platform stabilization
- Shock monitoring systems
- Robotics
- Tilt sensing
Main features and benefits
- 10-year longevity
- Best in class vibration rejection
- 64 g programmable output
- Accelerometer thermal stability of 45 ug/C
- Accelerometer bias repeatability of 1 mg
- Gyroscope thermal stability of 7 mdps/C
- CRC-based error-detecting code algorithm
- Operating temperature range of -40 to 105 C
Filed Under: Sensor Tips
