One aspect in the manufacture of drugs is cleanliness; equipment may have to withstand harsh cleaning procedures to prevent contamination. Flat-I is a stainless steel, compact cylinder for applications in which frequent, corrosive wash downs are required to prevent the propagation of bacteria.
The cylinder that has mounting holes only where they are needed, with a clean stainless steel exterior. Because of the importance of sterility and the need for cleaning with high-pressure, high temperature sprays applied at close range, this cylinder has the highest possible rating on the Ingress Protection International Scale – IP69K, 6 for being dust-tight and 9 for protection against liquids.
The Stainless Steel Flat-I comes in a wide range of 8 bore sizes and breadth of cylinder options.
Bimba
www.bimba.com
Filed Under: TECHNOLOGIES + PRODUCTS
