Stanford Researchers Measure Concussion Forces in Greatest Detail Yet
By atesmeh | January 13, 2015
Although the mechanisms of concussions are still being revealed, David Camarillo’s lab has measured the forces imparted on the brain in greater detail than ever before. The results could eventually lead to better injury detection and prevention.
David Camarillo, assistant professor of bioengineering, leads a team of researchers that has developed equipment to measure the magnitude and types of force exerted on football players' heads and necks during games or practices. (Photo: Saul Bromberger and Sandra Hoover)More than 40 million people worldwide suffer from concussions each year, but scientists are just beginning to understand the traumatic forces that cause the injury.
Now a team of engineers and physicians at Stanford has provided the first-ever measurements of all the acceleration forces imparted on the brain during a diagnosed concussion. The findings could lead to better injury detection or toward developing safer protective gear.
The study was recently published in the online edition of the Annals of Biomedical Engineering.
Previous research has measured the translational forces – up/down, left/right, front/back – of concussion events, but scientists have long believed that rotational accelerations play a prominent role in the injury.
The Stanford researchers, led by David Camarillo, an assistant professor of bioengineering, outfitted Stanford football players, local boxers and mixed martial arts fighters with sensor-laden mouthguards that can measure rotational accelerations on the head – roll, pitch and yaw – as well as translational forces.
Clearest Picture Yet
The mouthguard was originally developed by X2 Biosystems for consumer use, but Camarillo’s lab has customized the device for research, allowing the researchers to create the clearest-ever picture of the forces imparted on the head during an impact.
The mouthguards recorded more than 500 impact events during regular sporting events. Two of these impacts resulted in diagnosed concussions and are believed to be the first-ever concussion events to be recorded with six degrees of freedom.
Statistical analysis of the impacts revealed that measurements made with six degrees of freedom were more predictive of injury than those made with the standard three degrees of freedom. They also found that rotational accelerations were a stronger predictor of injury than translational forces.
The results put the researchers one step closer toward identifying a benchmark combination of accelerations that indicate a brain injury, but Camarillo said the small sample size of the current study means that much more research is needed to do so.
“I should stress that these are still very early results with only a few concussions so we still don’t know what causes concussion,” Camarillo said. “The data does support the rotational acceleration hypothesis, but not overwhelmingly. But the data is compelling enough to suggest we continue to collect this data and see how our results hold for a wider variety of concussions.”
The current work, however, has helped identify a brain structure that bears closer scrutiny for its potential role in concussion symptoms. While the two concussion impacts inflicted very different magnitude and directional forces on the head, computer models indicated that they both put strain on a particular part of the brain, the corpus callosum. Previous concussion studies have identified the corpus callosum as a potential injury site.
“One of the things the corpus callosum does is manage depth perception and visual judgment by communicating and integrating information from each eye across the left and right hemisphere of the brain,” said lead author
Fidel Hernandez, a mechanical engineering graduate student in Camarillo’s lab. “If your eyes can’t communicate, your ability to perceive objects in three dimensions may be impaired, and you may feel out of balance, which is a classic concussion symptom.”
New Standard Sought
The industry standard for evaluating helmet effectiveness involves measuring only the three translational degrees of freedom. By continuing to suggest the strong connection between the rotational forces and incidence of injury, the Stanford group hopes it can influence industry to apply rotational tests to evaluate existing gear, or to even design helmets that minimize rotational effects.
Real-time monitoring of head accelerations could also help limit the frequency and severity of injuries in sports. Sustaining a second injury shortly after the first can exacerbate the trauma and lengthen recovery time, but athletes often don’t realize – or don’t report – the initial injury. If future research can identify a minimum force required for injury, medical professionals could remotely monitor a player’s head impacts throughout a game and pull the player to the sideline before he or she sustains greater injury.
An ongoing complexity involved in this line of studying concussions, Camarillo said, is that many injuries go unreported by players. For instance, Camarillo’s research group members had expected that by measuring head rotation, they would see a clear threshold between concussive and non-concussive impacts, which has eluded previous studies. But even among the few concussions they measured, there were other impacts with higher rotational acceleration but with no clinically diagnosed concussion.
Camarillo said that other factors could account for this discrepancy – such as variations in individuals’ tolerance to concussions or the player’s bite affecting the mouthguard’s measurements – but that he believes underreporting is the main culprit.
“Stanford has careful clinical surveillance and player education so we thought anyone with symptoms would be detected,” Camarillo said. “Under-reporting has plagued research studies and is a major problem in player health that may still be unresolved.”
For more information visit www.stanford.edu.
