Sub-miniature Right Angle Gearbox from Rino
By Miles Budimir | June 11, 2010
The made in USA Rino Custom sub-miniature right angle gearbox is designed and built to meet the customers need for a light weight, mil-spec, 1:1 ratio gearbox.
rino-Miniature-Bevel-Gearbox-with-Handle-
Using a shaped machined aluminum block housing, light weight gears and shafting, we reduced the weight by 35% over the previous design. Ball bearings, shaft seals and low temperature grease are part of the design. Shown in the photo is the custom handle that Rino supplies with the gearbox.
This custom design L shaped gearbox is engineered to fit the customer’s unique packaging needs. It is only 1-3/8 by .1-3/8” by 5/8” and has a torque rating to 6 inch-lbs.
Rino Mechanical Components Inc.
http://www.rinomechanical.com/gearbox_miniature.htm
Filed Under: Packaging, Gears • gearheads • speed reducers, Mechanical
Tagged With: rino mechanical
Comments
  1. John says
    February 7, 2019 at 4:03 pm
    Where can I purchase the Rhino mini gear box ?
Finalists announced in Mechanical category for the 2019 LEAP Awards
keysight
Gallery: Auto technology on display at the Automotive Testing Expo 2019
Death of the shadetree mechanic?
EXAIR offers high-capacity quality HEPA vacuum
