Switch Provides 16 Ports in an 8-port Sized Box
By Design World Staff | May 7, 2009
The high-density EISK16 switch occupies minimal DIN-rail space: 1.6 in. or 41 mm. The Plug-and-Play (PnP) EISK16-100T compact switch has 16 copper 10/100 Mbps ports in a box smaller than a standard EIS 8-port unit. It is encased in a metal enclosure.
Marketed under the CTRLink‚® trade name, it expands the family of Ethernet 5- and 8-port switches. Just power it up, and this unit will auto-configure each port for data rates at 10 or 100 Mbps and straight-through or crossover cable requirements. These ports support half-duplex operation with backpressure flow control or full-duplex operation with PAUSE control.
Low-voltage 10-36 Vdc or 24 Vac (‚±10%) 47-63 Hz powers this product. It will operate in 0‚° to +60‚° C temperatures.  The auto-negotiation protocol allows this switch to link with any compatible 10BASE-T or 100BASE-TX device. It will function with any application layer that works with Ethernet including Modbus TCP, BACnet‚®/IP or EtherNet/IP‚â„¢.
Contemporary Controls
www.ccontrols.com
Filed Under: Ethernet — cables • hubs • switches, Networks • connectivity • fieldbuses
Ethernet/IP Network specification complete for Ethernet-Apl physical layer for process automation
Avnu Alliance launches global TSN Certification program
Hardened multi-speed mega PoE injector for diverse infrastructure applications
EKI-7000 Series Firmware Revision makes network management more secure
