TDK-Lambda 2500 Watt Server Power Supply Achieves 80 PLUS® Platinum Efficiency
By Natasha Townsend | July 13, 2012
TDK Corporation announces that the TDK-Lambda previously released HFE2500-48 power supply has now been certified to the stringent 80 PLUS® Platinum level for redundant, server, and data centre applications.
Achieving over 94% maximum efficiency, the HFE2500-48 operates from a universal AC input of 85 to 265 Vac and provides a dc output of 12 V, 24 V or 48 V. With the 19-in. rack-mount enclosure, as many as 4 supplies can be paralleled with automatic load-sharing to provide up to 9.5 kW of output power.
TDK-Lambda
www.uk.tdk-lambda.com
Power Supply Tips
Filed Under: Power Electronic Tips
Tagged With: TDK-Lambda
schurter
Compact power entry module has side flange mounting option
ABSOPULSE
Three-phase power supplies with active PFC handle 5-kW industrial applications
Sager Electronics to carry SL Power’s 300-W single-output power supplies
wuerth catalog
Catalog covers certified components for automotive electronics
