The NaviTEK II is one of the fastest, most cost-effective Ethernet Service and Cable Testers. The tester includes IPv6, PoE+, VLANs, Trace Route, and advanced color LCD screen to view standard pin-by-pin, wire-map capabilities in modern network deployments. The tester features a simplified user-interface that lets even inexperienced technicians get networks back up and running fast. It has a 3.5-in. color LCD with large fonts and an on-screen keyboard to speed data entry of IP addresses and customer information. Steering through the tester’s capabilities poses no challenge thanks to a 5-way navigation buttons used for data input, along with an intuitive set of icons. The tool lets users test cabling and network performance using the same RJ45 interface, eliminating need to disconnect the cable from the unit to switch between cable and network tests.Ideal Industries
www.ideaindustries.com
Filed Under: Renewable energy
