This Smartphone Brings Tango, Google’s Augmented Reality Platform, To Life
By Janine E. Mooney | June 10, 2016
This is exactly what Elon Musk was afraid of.
The first consumer smartphone that enables Project Tango, Google’s augmented reality platform that gives your smartphone a sense of its own surroundings.
The Lenovo Phab2 Pro, which supports Project Tango, has been unveiled together with two mid-range handsets from the same line.
Project Tango maps out the environment around you in three dimensions, so navigation can be more precise, games can be more immersive, and apps can take advantage of knowing everything that’s around them without GPS or pre-loaded maps.
The Phab2 Pro is boasts a 6.4-inch Quad HD (2,560 x 1,440 pixel) screen, weighs 0.57 lbs, and is about 65 percent heavier than the Samsung Galaxy S7 Edge and the iPhone 6s Plus. A bit of a brick, if I do say so myself.
Thanks to the extra sensors in the phone, there are three main technologies at work: motion tracking, depth perception, and area learning. In addition, the smartphone is capable of taking 250,000 measurements every second.
Let’s dig inside! The Lenovo Phab2 Pro includes the following components:
  • Snapdragon 652 CPU (custom-made for Tango)
  • 4 GB of RAM
  • 4,050 mAh battery
  • 16 MP camera (fitted with the depth sensor and motion tracking technology)
Essentially, Project Tango allows you to see how a virtual couch looks in your living room, then walk around it in 3D, or being able to get precise directions in an office block where there’s no GPS signal. Imagine that!
There’s also a gaming aspect—you can shoot blocks and lasers that appear to bounce of your living room walls. The difference between this and similar technology we’ve seen on the market, is that all of the sensors are stored inside your smartphone rather than a headset.
In addition to the Tango-enabled Phab2 Pro, Lenovo has also announced the Tango-less Phab2 Plus and Phab2, with reduced specs and lower prices. Both phones boast 6.4-inch displays, but with reduced resolutions (1,920 x 1,080 for the Phab2 Plus and 1,280 x 720 for the Phab2). And, the mid-range Phab2 Plus comes with two 13 MP rear cameras. All three will be available come September.
Check out the video below, which shows Google’s original Project Tango prototype in action.
Machine Learning for Sensors
Going small with 3D printing
