CHALLENGE
A tricky installation process regularly led to bearing damage and compromised performance for a busy lumber mill in Idaho. The previous ball housed units created a drag on profitability and productivity across the operation, leading the customer to need a more cost-effective and high-performing solution.
SOLUTION
The Timken Fafnir ball housed unit with shaft guarding technology (SGT) proved ideal for applications throughout the mill. Installing the same way as a standard setscrew bearing, operators enjoyed a simplified installation process. The Timken unit’s stainless steel SGT ring construction also helps prevent shaft damage during installation and operation for improved overall performance.
RESULTS THAT MATTER
• SGT helps prevent shaft damage
• Improved bearing performance
• Increased bearing life
Timken
www.timken.com
Filed Under: Bearings
