For augmented and virtual reality devices, as well as other 3D world-facing applications, the focus is on maximum user experience combined with compact and lightweight design. In the 3D sensing market, Vertical Cavity Surface Emitting Lasers (VCSEL) have a huge impact due to their good beam quality, cost efficiency, and simple design.
Bidos P2433 Q is available in four different versions including two different fields of illumination and two output power levels. The VCSEL-based modules with a size of 3.3 mm x 2.4 mm are suitable for 3D sensing applications using Time-of-Flight (ToF) measurement, which requires a homogeneous illumination of the scene. Due to their wavelength of 940 nm, all modules are also free from the red glow effect, which is perceived by the human eye as disturbing flickering.
The two higher power modules with 6.5 watts use dual-junction VCSELs for outstanding performance and efficiency of up to 45%. In addition, a photodiode monitoring system is integrated into the module as a special protection mechanism for eye safety. If the photodiode registers a change in the incidence of light – for example, if the optics are damaged – the current supply to the VCSEL is interrupted.
Besides 3D gesture recognition, the four new modules can also be used in industrial robotics for obstacle avoidance and virtual fencing, or in 3D face authentication systems in smart door locks or point-of-sale payment terminals.
Filed Under: Sensor Tips
