Carlo Gavazzi introduces the new UA Series ultrasonic sensor family with improved functionality in a state of the art design.
The UA Series features longer sensing ranges and an excellent cost/performance. With their simple teach procedure and shorter M18 or M30 diameter housing, the sensors are ready to tackle the most difficult distance and level applications.
This new UA Series of ultrasonic sensors has two different output configurations. The first has two digital outputs in either NPN or PNP. The second has an analog output in either 4-20 mA or 0-10 VDC, as well as one digital output in NPN or PNP. The two digital outputs can be set as standard switching outputs with two set points or as a window function. The analog output can be set with a positive or negative slope for both filling and emptying applications.
The sensors are available in four different sensing distances: 400, 900, 2,200 and 3,500mm. They come with both pre-cabled or M12 connector versions. They are designed for use in a wide variety of applications, including material handling, food & beverage, packaging, plastics, agriculture, printing and automotive.
Carlo Gavazzi
www.GavazziOnline.com
Filed Under: Cables + cable management, Sensor Tips
