Wireless LAN Ethernet
By Design World Staff | June 17, 2010
The Rugged Wireless LAN Ethernet Port Adapter – RWE231i (2.4GHz) and Rugged Wireless LAN Ethernet Port Adapter – RWE241i (5GHz) suit installations where there is a need for replacing the Ethernet cable with a maintenance-free wireless connection, or to connect to an existing Wireless LAN infrastructure. Both products have applied the IEEE 802.11n.
Wireless-LAN-Ethernet-Port-Adapter---RWE241i
The products support WEP64, WEP128, WPA-PSK, WPA2-PSK, TKIP, CCMP (AES), LEAP, PEAP and are radio type approved for Europe, US and Canada (R&TTE, FCC, IC). Further, the products are configurable to optimize for Profinet.
connectBlue
www.connectblue.com
Filed Under: Wireless, Networks • connectivity • fieldbuses, Wireless devices
MTConnect Institute releases Version 2.0 of the MTConnect Standard
OPC UA
Everything is moving – OPC UA Companion Specification “Global Positioning”
Single common conformance test plan to be available for the IEC/IEEE 60802 TSN profile for industrial automation
Ethernet/IP Network specification complete for Ethernet-Apl physical layer for process automation
