Zero-Max expands Posi-Lok keyless shaft bushing product line
By Mike Santora | June 12, 2019
Zero-Max-Posi-Lok-Product-Line-ExpansionZero-Max announced expansion of its Posi-Lok keyless shaft bushings product line. These shaft locking devices rigidly secure shaft-mounted components into position. They are an excellent shaft-hub locking solution eliminating keyways which can weaken or cause excess wear to shaft components.
The expanded Posi-Lok product line includes nine different models in a range of sizes. Now available are more model and size options to handle different torque requirements and mounting configurations for unique motion control applications. Also available are more material choices to meet specific application requirements such as corrosion protection as well as environmental considerations. Most models are available to ship from stock.
All Posi-Lok models easily slide onto a shaft and provide reliable, zero-backlash performance. They provide excellent concentricity with minimal radial and axial runout. Their field-proven mechanical design does not require keyways thereby reducing machining costs.
Included among the new models and sizes are stainless steel models for use in highly corrosive applications such as food processing, chemical processing and others that operate in harsh environments. Also available are electroless nickel plated models and standard alloy steel models.
Zero-Max is a leading provider of motion control solutions and one of the industry’s most trusted coupling manufacturers. The company provides shaft couplings, right angle gear drives, overhung load adaptors and other precision motion control components. Zero-Max products are known throughout the world for their innovative designs, high quality, high performance and durability.
Zero-Max
www.zero-max.com
Filed Under: Coupling Tips, Collars • locking devices
Tagged With: Zero-Max, Zero-Max-Inc
Friction bearing universal joints for packaging applications
Sensata Technologies adds Predictive maintenance for rotary equipment
KTR RUFLEX torque limiter with BoWex gear coupling
Ringfeder on Carlyle Johnson JEB electric jaw clutches
