HVAM High Voltage Axial Leaded Resistors Released
Stackpole Electronics, Inc. announces the release of the HVAM series of high voltage axial leaded resistors. The HVAM deposition technology produces a non-inductive resistive element with high stability, low noise and high voltage ratings. Precision tolerances are available down to 0.1% with TCR as low as 50 ppm. Resistance values range from 500 Kohm to 10 Gohm, depending on resistor size and tolerance. Sizes and maximum working voltage ratings are as follows:
* HVAM20 – 2W power rating, 15,000 volts
* HVAM36 – 3.6W power rating, 15,000 volts
* HVAM50 – 5W power rating, 20,000 volts
* HVAM75 – 7.5W power rating, 30,000 volts
* HVAM10 – 10W power rating, 50,000 volts
The HVAM Series is ideal for high voltage medical applications, voltage dividers, high voltage power supplies, avionics and aerospace, industrial equipment, and telecom infrastructure and equipment.
Pricing for the HVAM depends on size, resistance value, tolerance and TCR. Contact Stackpole or one of our franchised distribution partners for specific pricing.
Stackpole Electronics Inc.
www.stackpoleengineering.com
Speak Your Mind
