TWINSBURG, OH ‚– Pepperl+Fuchs introduces VBA-4E4A AS-Interface Junction Box Modules. VBA-4E4A modules are just 28.65 mm (1.128 in.) high and deliver 4 in/4 out functionality to support up to 62 nodes per network. All I/O is powered directly by the AS-Interface module, eliminating the need for any additional sources of power.
Industrial Dual Lock‚â„¢ mounting strips are included and increase the total mounting height to just 35 mm. Removable terminals make programming and module change outs quick and easy, and LED indicators help to debug and troubleshoot any programming issues.
These modules are designed exclusively for use with AS-Interface 3.0 scanners and gateways, and are intended for use with two or three wire type sensor inputs, or dry contact pushbuttons.
Filed Under: CONNECTIVITY • fieldbuses • networks
