    • On the Floor
ABB helps iconic Maid of the Mist boats go green
By Paul Heney | June 5, 2023
The new electric Maid of the Mist sits at the dock, behind one of the old diesel models.
Anyone who’s visited Niagara Falls in the summer has surely watched the famed Maid of the Mist boats ply the waters of the Niagara Gorge. These sightseeing tour vessels, which appear tiny from above, seem to get perilously close to the thundering water from both the American and Canadian falls, crashing down roughly 180 feet. Now, the American operator of the two ships has decided to move into 21st Century technology with all-new craft that use ABB zero-emission technology to power the fully electric ferries. These new ferries can hold 600 passengers each and replace the former diesel vessels.
Design World recently received an exclusive invite to tour the new boats, including getting down below the hatches and taking a ride into the mist.
The Maid of the Mist Corp., founded in 1846, is family owned and operated. This step forward to demonstrate the commercial viability of all-electric boat technology has attracted global attention to the company. The Niagara boats are believed to be among the first all-electric vessels — but won’t be the last. Industry experts say that passenger ferries, river barges, harbor tugs, and dredgers are well-suited to all-electric operation.
The new electric Maid of the Mist heads toward the falls.
ABB noted that marine vessels are one of the largest contributors to transportation emissions (3-5% of global CO₂ and more than 5% of global SOx), so electrification of shipping cannot come soon enough. Today, it would be difficult to build 100% electric ocean-going vessels. However, as equipment becomes smaller and more cost-effective, new opportunities keep opening. Autonomous, all-electric seagoing vessels may be possible and practical in years to come.
New horizons in marine battery technology
Global interest in marine electrification is being spurred on by, for instance, new International Maritime Organization rules, such as the 2020 IMO fuel sulfur regulation, which will reduce the limit on the sulfur content of bunker fuel. Maritime operators are, therefore, keen to explore fuel cell technology.
Jon Diller, the commercial director for Kansas City-based Spear Power Systems, explained that the batteries used on the ferries are split between left and right sides; each side has 168 kWh of embedded energy, so it is a 316- kWh vessel. The batteries are arranged based on the Spear energy module, which uses a rectangular pouch cell from LG Chem.
The ship’s power distribution station, located below the main deck copy.
“Each module has 64-amp hours, which makes it roughly 21 times the size of the cell that’s in a cell phone. We take two of those and put them in parallel, and then take 24 and put them in series. That produces a module that has 11.3 kWh of embedded energy. That’s an 11-kWh unit, and it has a 100-volt maximum voltage,” Diller said. “We then take that module and put it in series with other modules to get to the system voltage that’s desired to work with the propulsion system. In this case, the drives want their voltage range to operate somewhere between 640 volts and 420 volts. So, I go with seven modules in series to get to a maximum voltage of 100 volts.”
From a safety standpoint, Diller said that there’s a battery management system to stop the electrical abuse of the battery. It prevents operators from doing the things that will cause a battery to catch on fire: overcharging it, charging it too fast, charging it when it’s frozen, or charging it after it’s been depleted to a 0% state of charge.
Charging and propulsion
The Maid of the Mist boats set off from a downstream landing to head toward the base of Niagara Falls daily, serving more than 1 million guests each year. While the ferry is docked and passengers are embarking and disembarking, the new boats’ lithium-ion batteries are partially recharged. The seven-minute charge provides a battery boost enabling the vessel’s dual electric propulsion motors to maintain their total output of 400 kW (563 hp). Each trip consumes about 38 kWh. The batteries still have 80% power at the end of the working day.
The Maid of the Mist hooked up at the daytime charging station.
According to Esteban Guerrero, master electrician for Maid of the Mist Corp., they have two charging stations.
The company uses a daytime charging station, and a nighttime charging station. The nighttime charging station is a trickle charge, with about 30-40 volts. The one the company uses during the day has a high output of 600 amps that charges the unit within seven minutes.
There are two motors operating L drive 360° directional thrusters in the stern (rear) of the boat (for propulsion), and there are two bow thrusters in the front that help with directional control. The result is a very maneuverable craft.
One of the ship’s rear thruster L drives.
The old boats used a common straight shaft diesel design for the rear propeller. Kyle Taylor, one of the Maid of the Mist captains, explained that if you were to simply convert that setup to electric, but using the same basic transmission and components, the result would be much less efficient. So instead, the team decided to go with azimuth drives operating a propeller underneath the water. “It just made total sense for what we were doing here,” said Taylor.
Taylor said that the rear thrusters use L drives manufactured by Veth Propulsion (a division of Twin Disc, Inc.) and that maximizing lifespan and minimizing downtime are key concerns of Maid of the Mist Corp.
“These L drives have a super-low profile and are easy to maintain,” Taylor said. “We’re spoiled for space here, so we can crawl all around them. The goal is to have a warehouse full of spare motor drives and all the other components to minimize downtime. Our Veth drives are about 250-hp equivalents; there’s one per side, a 200-kW electric motor that we run at a maximum 80% output. So, it’s the same as the batteries — we don’t really charge above that or use components above that. We just try to get a long lifespan out of things.”
Even more green
ABB is supporting e-mobility for applications outside the maritime world as well — for example, with public and private EV charging solutions. By early 2019, more than 10,000 ABB DC fast chargers had been sold in 73 countries. Looking ahead, products such as the company’s Terra HP high-power charger are designed to accommodate the higher-­capacity batteries of tomorrow.
Additionally, ABB is helping stakeholders across the globe establish electric bus services that reduce human impact on the environment. The company launched its first DC fast charger in 2010, the first nationwide DC charging networks in 2012, and the first eBus charging networks in Europe in 2016.
ABB
www.abb.com
Filed Under: Batteries, Energy management + harvesting, ELECTRONICS • ELECTRICAL
Tagged With: abb
Paul Heney
    • On the Floor
