EnvisionTEC and Henkel are expanding their partnership agreement. Over the past two years, the companies have collaborated on a variety of unique applications. With the launch of EnvisionTEC´s next generation Xtreme DLP and Envision One cDLM HT printer technologies and the expansion of Henkel´s industrial grade materials portfolio the companies are positioning to support the volume production of end-use parts.
Both companies have already engaged in printing parts for the medical and industrial sectors. Henkel’s new materials are designed to create a shift in photopolymer material chemistry and to deliver FDM function with the surface finish and accuracy of SLA/DLP using EnvisionTEC’s high-speed production systems. The partners aim to leverage this material know-how in accelerating the adoption of DLP technology in the industrial production. The combination of Henkel´s material expertise and EnvisionTEC´s printer technology enables the creation of parts that are stable over time without losing mechanical properties, becoming brittle over time, or changing color while maintaining accuracy and surface finish.
EnvisionTEC’s continuous Digital Light Manufacturing (cDLM) High Temperature (HT) technology will be included in Henkel’s broad 3D printing ecosystem. The partners will also collaborate for Loctite branded formulations validated for use on the Xtreme DLP Machine. This new large format 3D printer allows for the production of large 3D parts, built at fast speeds without sacrificing surface quality and part accuracy.
To kickstart the launch of this partnership, Henkel’s Loctite-branded photopolymer materials have been validated on EnvisionTEC’s continuous Digital Light Manufacturing (cDLM) High Temperature (HT) technology platform and XtremeDLP printer:
- Loctite 3D 3955 HDT280 FSTis a key halogen free material offering flame retardant properties with extremely high HDT (heat deflection temperature). This material is the first 3D photopolymer that passes vertical burn and aerospace FST standards.
- Loctite 3D IND406 HDT100 High Elongation is a tough material with good dimensional stability and is ideal for tooling, interior and machinery parts. This material can be used for final parts production in automotive, consumer goods and general manufacturing.
- Loctite 3D 3843 HDT60 High Toughness is a high impact resin with excellent surface finish ideal for durable parts production, tooling and low temperature molding applications across industries.
- Loctite 3D IND402 A70 High Rebound is a high rebound elastomer which does not require thermal post processing and is ideal for lattice structures as in midsoles/soft inserts.
Said Dr. Simon Mawson, Senior Vice President and Global Head of 3D Printing at Henkel, “EnvisionTEC’s E1 High Temp printer allows Henkel to move beyond the boundaries of viscosity limitations by enabling highly viscous or solid resins, such as Loctite 3955 FST, the first 3D photopolymer that passes vertical burn and aerospace FST standards and Loctite IND402, a single component elastomer material with high resilience and tensile strength, to be heated and printed under controlled conditions. These new generation Loctite materials combined with EnvisionTEC E1 High Temp printers will accelerate the adoption of industrial additive manufacturing.”
Henkel
www.henkel.com
EnvisionTEC
envisiontec.com
Filed Under: Make Parts Fast
