Advantech’s Launches Industrial Monitor
By Design World Staff | July 16, 2008
Cincinnati, Ohio ‚– The Industrial Automation Group of Advantech introduces the FPM-5151G 15‚” (1024 x 768 resolution) LCD flat panel monitor specifically designed for industrial applications. The FPM-5151G features direct-VGA & DVI-D signal transmission, which allows any VGA control card to be used in your system.
There‚’s an on-screen display feature that allows the user to adjust the images on the screen. A front access USB connector provides easy access to the controller through an USB extension cable. Other features include: lockable OSD keys with two user-defined contrast/brightness settings, 10-30 VDC power input, and as an option a combo RS-232 & USB interface for the touchscreen function.
The FPM-5151G has a NEMA 4/IP65 compliant aluminum die-cast flat-sealed front panel with an anti-rust chassis. It supports panel, wall, desktop, rack, or VESA arm mounting. The FPM-515G is idea for factory and machine automation display solutions.
www.advantech.com
Filed Under: Industrial computers, ELECTRONICS • ELECTRICAL
