Agilent Technologies Introduces High-Definition Oscilloscopes
By Test and Measurement Editor | January 10, 2013
Agilent Technologies Inc.  introduced Infiniium 9000 H-Series high-definition oscilloscopes. The four new models come in bandwidths of 250 MHz, 500 MHz, 1 GHz and 2 GHz. They offer up to 12-bit vertical resolution, which represents 16 times the quantization levels of traditional oscilloscopes with 8 bits of resolution. These scopes also include the industry’s deepest standard memory (up to 100 Mpts per channel).
When engineers view small signals, noise is often the biggest impediment to getting an accurate measurement. The 9000 H-Series uses a combination of hyper sampling and linear noise-reduction technology to provide noise levels three times lower than traditional 8-bit oscilloscopes. This reduced noise enables users to view and resolve small signals that 8-bit oscilloscopes simply cannot measure.
As probing systems also induce measurement noise, Agilent has developed a new series of low-noise probes specifically designed to allow engineers to view and analyze small-current signals. The new N2820A and N2821A AC/DC current probes offer the industry’s highest sensitivity, going all the way down to 50 uA, with a maximum current range of 5 A. These probes work in cooperation with the new oscilloscopes to offer the industry’s most sensitive current measurements. The higher sensitivity is especially useful for measuring current consumption of battery-powered mobile devices or integrated circuits.
The proliferation of mobile devices and “green” products has created a growing need to make low-power, high-dynamic-range measurements. As products get smarter and more feature rich, all components need to be more energy efficient. The 9000 H-Series oscilloscope with the N2820A and N2821A current probes are specially engineered to make high dynamic range, high-sensitivity measurements to meet today’s challenging current measurement needs.
The N2820A current probe interface uses a make-before-break connector, offering easy and reliable connecting and disconnecting without interrupting the circuit under test across multiple locations on the target board.
The Agilent 9000 H-Series provides standard memory of up to 100 million points per channel, making it the deepest standard memory in the industry. This memory depth can be upgraded to 500 million points per channel to acquire longer windows of time while retaining fast sample rates.
www.agilent.com
Test & Measurement Tips
eBay
When to buy used test equipment
TRACO Power now sells cost-optimized 1-A POL converters with 6-to-36-V input range
eye diagram
Simpler debugging for Automotive Ethernet systems
E+H-Prosonic-flowmeter
Flowmeter for industrial water, feedwater, cooling water and condensate
