AIV series air-piloted media isolation valves from Clippard
By Mary Gannon | January 12, 2024
Like Clippard’s NIV and PIV lines of isolation valves, the AIV series features Clippard’s unique multi-functional valve stem design for longer life and minimal dead volume. The difference with the AIV series is that is that it also provides the added benefit of air operation, which is — by definition — intrinsically-safe.
Clippard-AIV-Isolation-Valves-web
No solenoid means absolutely no heat build-up from the coil, making the AIV series ideal for applications that utilize temperature-sensitive media. All wetted areas are PTFE and PEEK, making it ideal for use with corrosive media.
Features include:
  • Zero power consumption (air-operated)
  • Excellent intrinsically safe valve substitute
  • No heat build-up
  • Compact, lightweight design
  • Bidirectional
  • Minimal dead volume
  • Fully flushable
  • All wetted areas PTFE or PEEK
  • High cycle life
  • Fast response time
    Proudly made in the USA
Clippard
www.clippard.com
Filed Under: Pneumatic equipment + components, Valves, FLUID POWER, MOTION CONTROL
Tagged With: clippard
