Antenna Factor announces the immediate availability of 2.4GHz versions of its popular PW and CW Series antennas. These durable, classically-styled dipole antennas are well suited for a wide range of industrial, medical, sporting and consumer applications.
The PW version is designed for permanent attachment, and connects via a coax cable that can be terminated with a connector or soldered directly to the product‚’s PCB to save cost. The CW Series incorporates an integral standard SMA or FCC Part 15 compliant RP-SMA connector. Both versions feature a
wide useable bandwidth, low-VSWR and an omni-directional pattern. An internal counterpoise eliminates external ground plane dependence.
Antenna Factor
www.antennafactor.com
Filed Under: Wireless • 5G and more, ELECTRONICS • ELECTRICAL
