Aurora Bearing’s CM/CW-ET Series Rod Ends
By Design World Staff | May 7, 2008
The Aurora CM/CW-ET series features bodies made from heat treated 17-4PH material. They offer excellent corrosion resistance compared to conventional rod ends and they provide greater load capacity, strength and durability as well.
The ET series comes standard with Auroras exclusive AT2100 PTFE liner. This, combined with a heat treated 440C stainless ball, gives a durable, zero clearance, self lubricating, maintenance free bearing interface to go with the benefits of the heat treated body. Their two piece design allows these high performance features to be exploited at an economical price. The Aurora ET series bearings can be used to enhance the performance of equipment in wash down, marine, and other environments that require extra corrosion resistance.
www.aurorabearing.com
Filed Under: Bearings, Fastening + joining • locks • latches • pins
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
