Marathon mounted bearing units integrate a stainless steel dual-sealing system to protect from contaminants, resist corrosion, and extend service life.
The sealing arrangement consists of a double-lip insert seal (rubber bonded to AISI 304 stainless steel), an AISI 304 stainless steel flinger, and a rubber-backed steel gasket. The insert seal and flinger combine to create a double barrier against pollutants and washdowns, and the gasket, flinger, and USDA Food Grade grease between insert seal and flinger deliver added sealing efficiencies. Stainless steel contributes superior corrosion resistance.
SKF USA, Inc.
www.skfusa.com/mrc
:: Design World ::
Filed Under: Bearings, Fastening + joining, Seals • gaskets • O rings
