Behlman announces the reconfigured Open VPX VITA 62 compatible 3U VPXtra™500M1 Power Supply, and the VPXtra™ Reconfiguration Program
By Frank Tobe | September 6, 2016
behlman-vpxtra-500m1Behlman Electronics Inc., is known for its leadership in providing power products for industrial and commercial applications, as well as for military shipboard, airborne and mobile programs. Working within its new VPXtra™ Reconfiguration Program, Behlman has modified the VPXtra™500M to create the new VPXtra™500M1, with 80 amps of 5 VDC output. This unit, in conjunction with the standard VPXtra500M, can supply 120 Amps of 5 VDC along with the customer-required 12 VDC and 3.3 VDC.
Complete specifications are available at http://www.behlman.com/uploads/prod_pdf/29_VPXtra500M1_SS_03_JUN_2016.pdf
In 2012, Behlman broke through the VPX power ceiling. That raised the bar higher than ever before, for the amount of power available in a single VPX power supply.
In 2015, Behlman broke through the VPX power intelligence ceiling. That enabled lower-cost creation of smarter systems having communication, measurement and control capability provided by the power supply.
Now, in 2016, Behlman has broken through the VPX power supply reconfiguration ceiling, enabling designers to specify – and receive – unique configurations that exactly meet their needs.
According to Behlman President, Ron Storm, “We listened to what many customers told us about their inability to maximize system performance using only standard VPX power products. As a result, we embarked on an ambitious reconfiguration program that lets design engineers ‘have it their way.’
Today, Behlman conducts conferences with concerned system designers, in which they specify and discuss their typical and non-typical VPX power supply requirements, which can vary significantly from system to system. Variables can run from different power levels of the standard voltages, to mechanical configurations, such as connectors, user-defined pins, and general interfaces. EMI filtering and hold-up requirements, as well as transient and lightning protection are other possible considerations. All-in-all, it turns out that industry standards set for VPX power supplies do not always satisfy the needs of systems requiring VPX power supplies.
The new Behlman VPXtra™ Reconfiguration Program is designed to address all these needs, and more. This program has already resulted in an impressive list of new, non-typical, COTS VPX power supply models (3U 3-phase AC to DC; High Voltage Hold-up card, Low Voltage Hold-up card; PS with extra 5 VDC, 6U 3-phase and single-phase AC to DC, PS with extra 12 VDC, PS with extra 5 VDC). But that is only the beginning. Behlman now invites all system designer to request additional system-specific VPXtra™ reconfigurations, without the cost of full-custom development.
A list with highlights of 14 presently available 3U and 6U standard and non-standard reconfigured VPXtra™ Power Supplies is available upon request, by sending an email to [email protected]. Some of these are so new that data and spec sheets are not yet published, but data and spec sheets for many can already be downloaded at
http://www.behlman.com/products_detail/vpx-power-supply
Behlman
www.behlman.com
Filed Under: Cables + cable management, Connectors (electrical) • crimp technologies, ELECTRONICS • ELECTRICAL
Tagged With: behlman
