Bison Gear Adds AC Offerings to FlexTorq™ Gearmotor Line
By Miles Budimir | June 10, 2009
St. Charles, IL – Designed as high torque, tight space drives, Bison Gear's new FlexTorq™ 762 series hollow shaft offset AC gearmotors feature either a 1.25″ (31.75 mm) I.D. hollow shaft or a 1.25″ diameter solid shaft in either the u-shaped or s-shaped configuration. Driven by 1/20, 1/4, or 1/2 hp (37, 186, or 373 W) single and three phase 115 and 230 volt AC electric motors these versatile fractional horsepower gearmotors operate with fixed output speeds from 60 to 1 rpm and offer continuous duty torque outputs from 430 to 2500 in-lbs (48.5 to 283 N-m) respectively.
The AC FlexTorq™ standard product offering includes two dual voltage (115/230) models, nine 115 volt models and four energy saving Verdant Duty™ three-phase models for use with variable frequency drives. Complete specifications and CAD drawings for these units are available at Bison Gear's new web site.
Bison Gear & Engineering Corp.
www.BisonGear.com
Filed Under: Motion control • motor controls, Motors (gearmotors)
49503-ACS Motion-CMxa
SDP-SI-040
PACMotion-servos
