Steinmeyer, Inc. announced an addition to its line of precision rotary stages. A torque motor for high-speed motion drives the DT240 stage. With an overall height of 100 mm and width of 240 mm this stage is ideal for applications requiring space saving solutions. The DT240 has a repeatability of +/-0.0001 degrees, a max speed of 480 rpm and a continuous torque of 8 Nm making it ideal for applications such as:
- Laser Machining
- Precision Wafer Inspection
- Photonics.
- Fiber Optics
The stage is also equipped with an angular encoder with resolution of 0.0001degrees, a contactless hall sensor for a reference switch and and is manufactured from a low distortion aluminum alloy which is black anodized
Steinmeyer Inc.
www.steinmeyer.com
Filed Under: Linear Motion Tips, Motors (direct-drive) + frameless motors
