Component Express, Inc. (CEI) announced its Index Mount adjustable camera mounts. Two different models are available—the Index and the Index Max. Both mounts feature a full 360 degrees of rotational freedom, with the Index and Index Max supporting 90- and 180-degree tilting, respectively.
These lightweight, low-profile camera mounts feature highly visible index marks around the swivel that streamline the setup process and enable repeatable camera positioning. Type 2 anodized aluminum bodies and strong tilt locks make these mounts suitable for rugged environments. In addition to their patent-pending design, the Index and Index Max include industry-standard mounting plates and are compatible with a broad range of automation components, not just machine vision cameras but also sensors, cables, lights and CEI’s IP67-rated enclosures.
Additional features include:
-Index (EN-M4)
-3.45 by 1.95-inch (88 by 50 millimeter) footprint
-Collet-style tilt lock
-Index Max (EN-M4X)
-3.75 by 2.75-inch (95 by 70 millimeter) footprint
-Taper-style tilt lock
Index Adjustable Camera Mounts are an effective solution for any machine vision application and are available at an attractive price point.
componentsexpress.com
Filed Under: Vision • machine vision • cameras + lenses • frame grabbers • optical filters • scanners
