Configurable Single-Axis Actuators
By Design World Staff | August 22, 2007
(Schaumburg, IL) -Misumi USA, Inc. announces the introduction of its single-axis actuators, available in 208 configured styles and a standard manufacturing time of 11 working days from receipt of order.  These new actuators are compatible with most servo motors and are designed to provide precision linear motion in a variety of general industrial assembly, as well as automotive, packaging and medical manufacturing applications.
New Misumi single-axis actuators are configurable in 208 styles and offer a standard manufacturing time of 11 working days.
    Each unit is a ball-screw driven device, built on a sturdy extruded 6063-T6 aluminum base with black anodized finish and 1045 steel side supports.  By configuring the precision grade C10 ball screw diameter (12-20mm) and lead (4-20mm), as well as the base width, stroke and table length, machine and equipment builders can design these actuators to suit the application at hand, without customizing a standard unit or building it themselves.
    Other features on these new Misumi single-axis actuators include a linear slide for medium or heavy loads, grooved base for sensor mounting, top plate with tapped holes for switch flags on both sides and a tight-tolerance bore (DH7) motor bracket to accept most popular 30-400W servos.  With high positioning repeatability as low as ±0.03mm and parallelism these actuators are able to suit demanding applications.  Maximum velocities are available to 1055mm/sec.
These new single-axis actuators from Misumi can be configured using the brochure that is now available at www.misumiusa.com/saa.
www.misumiusa.com
:: Design World ::
Filed Under: Actuators, Ballscrews • leadscrews, Semiconductor manufacture, Motion control • motor controls
