Connectors for Medium Voltage Cables Eliminate Need for Additional Tools
By atesmeh | May 12, 2011
Shearbolt Connectors from 3M create a reliable, consistent connection using continuous shearing determined by contact force not torque value. In addition, the bolt shears below the connector body because the bolt shears axially, not at a pre-defined shear point. This eliminates the need for filing and ensures the correct contact pressure. A friction plate on the bottom of the bolt prevents conductor damage while providing increased contact force. Designed for American Wire Gauge conductors, the new Shearbolt Connectors, QCI Series, meet the requirements of ANSI C119.4 Class 2. These connectors eliminate the need for crimp tools or dies and reducing installation error. The connectors are ideal for applications where limited space makes it difficult to crimp or where two different conductor sizes need to be connected. The Shearbolt Connectors, QCI Series, from 3M are available for low and medium voltage up to 46 kV and are designed to connect aluminum or copper conductors sized 2 AWG through 1000 kcmil (MCM), reducing the need and cost of maintaining a large connector inventory.
3M
800-225-5373, www.3m.com
Filed Under: Cables + cable management, Industrial automation, Connectors (electrical) • crimp technologies
