Connecting cables with plastic coupling nuts are an extension to the M12 connector family. Made from high quality PBT material for corrosion resistance and protection against aggressive chemicals and harsh cleaning agents, they are an alternative to stainless steel versions.
They are IP67 water- and dust-tight, and resistant to shock and vibration. They feature self-securing ratchet coupling nuts. The M12 single-ended and double-ended cables are available in 3, 4 and 5 pole configurations. These high flex PUR/PVC cables are rated for over 20 million bending cycles in continuous flex applications. Versions featuring PVC cables are also available.
Weidmuller
www.weidmuller.com
Filed Under: Connectors (electrical) • crimp technologies, Electronics • electrical, Fastening + joining • locks • latches • pins
