FasMate FN series connectors from FasTest Inc., Minneapolis, are designed for reduced insertion depth to internal threads. They provide safe and reliable instant manual or automated leak tight connections to shallow depth female threads. They deliver cost, process and quality improvement to a wide range of applications, including vacuum testing, media filling or flushing and performance testing.
Featuring a modular design, FN Series connectors enable rapid, effortless change outs between squeeze lever, pneumatic thumb and pneumatic pilot actuation methods to meet individual application requirements. They offer inherent flexibility, durable construction and easy field maintenance.
FN Series connectors are compatible with an extensive internal threaded port sealing range of 1/8 to 3/8 in. NPT, BSPP, SAE O-Ring Boss and ISO O-Ring Boss Metric sizes.
Their split collet operation uses no thread sealant or wrenches, and securely locks into place for instantaneous connections that will not disconnect under pressure. With durable stainless steel and anodized aluminum, these connectors can withstand pressures up to 2500 psi without the burden of expensive, time-consuming thread sealant and wrench tightening.
FasTest, Inc.
www.fastestinc.com
Filed Under: Cables + cable management, Pneumatic equipment + components, Connectors (electrical) • crimp technologies
