The Contour Grip is a modular ergonomic grip that incorporates controls on the front, side and back. Its ergonomic design was created with feedback from experts in the field including machine operators who tested it in a virtual reality environment. The shape was refined after multiple modifications to come up with the final user-friendly version. The design minimizes muscle strain in the arms and wrists allowing for extended use with minimal fatigue.
While the housing remains constant, the grips switches are configurable allowing for a selection of a multitude of different controls in varying locations. Virtually any OTTO switch can be used in the grip including Hall effect and electromechanical switches like OTTO’s HTW series thumbwheel switches, K series rocker switches, P and HP series pushbutton switches and T series toggle switches to name a few. This means that you can build your own grip based on application specific needs. Both left- and right-handed versions are available.
Made to withstand harsh environments, it can be used in construction, agriculture, forestry and industrial applications.
OTTO Engineering
Filed Under: Virtual reality, Test & Measurement Tips
