Control and monitor up to 32 channels of buffered drive TTL digital I/O via any 10/100BaseT Ethernet connection with the eI/O-160E digital I/O module. The eI/O module addresses the 32 channels of I/O as four eight-bit ports, each programmable as input or output. A 50-pin header connects the module to industry-standard solid-state relay racks to provide PC-based control of equipment including sensors, switches, security control systems, and industrial automation systems. For convenience, +5 VDC power is provided on the 50-pin connector.
The eI/O-160PoE has all the features of our eI/O-160E module and is a Class 0 (IEEE 802.3af-2003) Power over Ethernet device. This allows power and data to be transferred over a single CAT5 cable and eliminates the need for an external power supply.
Sealevel’s eI/O modules provide system designers with a compact, cost-effective alternative for monitoring and control. They are perfect for a wide variety of applications including process control, test & measurement, security, and broadcast automation.
Sealevel
sealevel.com
Filed Under: Power Electronic Tips
