Corrosion Resistant, Lightweight DC Pump from Thomas
By Design World Staff | October 20, 2008
The new 309 Series WOB-L DC pump and compressor from Thomas is small, lightweight (5.1 lbs./2.3Kg) and is manufactured with corrosion resistant materials on the inside and a corrosion resistant treatment on external components. Perfect for automotive applications including air suspension, air doors, air horns,
air brakes and clutches, and fuel systems, the 309 Series meets radiated emission requirements and is RoHS compliant.
The 309 Series also features oil-less operation, die-cast aluminum components, steel mounting brackets and isolators, all wetted aluminum parts, a stainless steel inlet valve and a thermally protected motor. The 309 Series provides up to 26.75 in.Hg (-904.1 mbar) and 160 psi (11 bar) of maximum intermittent pressure. In addition, the 309 Series has restart capability to maximum pressure.
www.gd-thomas.com/products
Filed Under: Automotive, Pumps
