Del-Tron Crossed Roller Tables
By Patrick Curran | September 1, 2009
Del-Tron’s aluminum and steel crossed roller tables are the perfect choice for applications requiring high accuracy and exceptional load carrying capabilities. Accuracies range from 0.0001” per inch of travel straight line accuracy on our aluminum tables to 0.00008” of parallelism on our steel crossed roller tables and are capable of carrying loads in excess of 2600 lbs.
The aluminum crossed roller tables are available with both inch and metric mounting holes. You can choose from our low profile LPT series with its 3 rail design or opt for our Gold Motion series with its flanged base and 4 rail design. Both are available with stainless steel crossed roller rails and roller cages for applications where corrosion resistance is a requirement. For vertical applications or applications involving high acceleration or deceleration forces you may want to consider our Anti-Creep crossed roller tables. These units employ a rail and roller cage design that eliminates roller cage migration or slippage due to load orientations or acceleration forces. Solid model drawings for our entire product line are available on our website.
Del-Tron Precision Inc.
www.deltron.com
Filed Under: Linear motion • slides, Motion control • motor controls
49503-ACS Motion-CMxa
SDP-SI-040
PACMotion-servos
Going small with 3D printing
