Desktop Metal announced it has qualified D2 tool steel for the Studio System 2, its metal 3D printing platform that prints metal parts in low volumes for pre-production and end-use applications. The company recently announced this material was qualified on its Production System.
The material allows customers to leverage a simple, nearly hands-free process to produce parts for high-strength D2 applications such as cold work metal forming tools, dies, punches, and injection molds with conformal cooling channels.
D2 is a versatile high-carbon, high-chromium air-hardening tool steel characterized by its high hardness and compressive strength after heat treatment. This tool steel offers extremely high wear resistance properties, dimensional stability, and corrosion resistance in the hardened condition, a key benefit for conformal cooling applications. D2 is used for a wide variety of cold work tools that require a combination of wear resistance and moderate toughness, such as coining and sizing tool members, blanking and forming dies, shear cutting tools, gauges, burnishing tools, and other wear parts.
With the Studio System 2, D2 tool steel parts demonstrate excellent mechanical properties on a more accessible platform than legacy powder bed fusion 3D printing alternatives. An example of a key use case includes:
● Stamping Tool – Aerial Cam Cutting Section
Aerial cam cutting section tools are a component of stamping dies that make frame components on high-volume vehicle manufacturing lines. D2 tool steel is a key material for this application because of its high hardness and excellent wear resistance, properties critical for stamping applications where the tool is subjected to repeated impact while forming. Stamping tools like these are produced in low volumes, traditionally using advanced machining techniques and slow feed rates because of the material’s high hardness. With the Studio System 2, businesses can now print these tools in D2 at low volumes cost-effectively while reducing complex machining operations, CNC fixturing setups, and CNC tool wear.
“Egar Tool and Die is a rapidly growing manufacturing company for automotive stamping dies, production stampings and welded assemblies and we have been eagerly awaiting the launch of D2 for our two Studio Systems,” said Colin Kools, Director of Additive Manufacturing at Egar Tool and Die. “The release of this material will serve to push our tooling design to new heights and will give us the critical material properties and hardness needed for our die components.”
The Studio System 2 – Office-Friendly Metal 3D Printing
The Studio System 2 is an office-friendly metal additive manufacturing system that leverages Desktop Metal’s proprietary Bound Metal Deposition™ (BMD) technology to produce parts. The easy, two-step process – allowing parts to be transferred directly from the printer into the furnace – provides a nearly hands-free experience, while eliminating loose powders and dangerous lasers commonly associated with metal 3D printing. Consisting of a printer and furnace, the Studio System 2 simplifies in-house low volume production of a wide range of complex geometries with outstanding surface finish and high-performance mechanical properties.
In addition to D2, the Studio System 2 is compatible with Ti64 and 316L stainless steel, as well as all materials previously supported by the Studio System, including 17-4PH stainless steel, 4140 low-alloy steel, H13 tool steel, and copper. A broad portfolio of additional materials that take advantage of the Studio System 2’s streamlined, two-step process is in active R&D with new releases slated to roll out this year.
Desktop Metal
www.desktopmetal.com
Filed Under: Make Parts Fast
