SAN DIEGO, CA – TDK-Lambda has introduced their new digitally controlled 300-watt power supplies that are designed specifically with medical applications in mind. With a 4kVAC reinforced input to output isolation and other specifications such as an output-to-ground isolation of 1500VAC, the EFE300M meets the rigorous international safety standards of IEC 60601-1 for medical equipment, making it suitable for use in B and BF type medical applications. Regulated DC outputs of 12V or 24VDC are standard and other voltages can be provided.
With a 3 x 6 inch footprint with less than a 1U profile (1.6″ max), the EFE300M can be incorporated easily into designs where space is limited so end equipment can be smaller and cooler. Other features such as a redundant operation capability and a high current standby output make the EFE300M equally suitable for high integrity applications including broadcast, instrumentation, routers, servers and security networks, as well as, ATE, factory automation and mechatronics.
The EFE300M series includes an integrated magnetics transformer (transformer and inductor windings on the same core) to boost efficiency to typically 90% and employs an 8-bit microcontroller for full digital control of the output and to handle housekeeping routines. This resulted in a 25% parts count reduction to achieve a 45% smaller, and up to 56% lighter design when compared to similar competitive products. Power densities of up to 16.6W/in3 are achieved under peak load conditions and 12.5W/in3 under continuous loading.
TDK-Lambda's control of the EFE300M allows the power supply's performance, such as current limit and start-up characteristics, to be optimized digitally — this feature eliminates the hardware changes usually required in analog designs. A low cost primary side control topology is used, supervised by the microcontroller. This results in fewer parts and higher efficiency without sacrificing load regulation performance. Furthermore, the need for an opto-isolator is eliminated — a device which is undesirable for long life power supply designs.
http://www.us.tdk-lambda.com/lp/products/efe-series.htm
Filed Under: Medical-device manufacture, Power supplies, ELECTRONICS • ELECTRICAL
