Eaton will use this year’s Hannover Fair as a platform to present its latest range of hydraulic, filtration, and electrical products and services that are cutting start-up times, reducing energy consumption and increasing efficiency for machine builders around the world. Eaton solutions will be featured in two locations: In hall 21, booth F03, Eaton will showcase its hydraulic and filtration products and in hall 11, booth C69 its full range of electrical products and services.
At both stands, Eaton will demonstrate its Lean Solution for machine builders that bring together the worlds of hydraulics and electrical engineering in automation. Eaton’s lean approach to machine building and manufacturing is unique to the market because it integrates electro-hydraulic systems in one comprehensive solution. This helps to reduce commissioning costs and energy while enabling diagnostic and energy management functions.
Visitors to Eaton’s stand in hall 21 will also see some of Eaton’s most innovative hydraulic products including LifeSense hose monitoring technology, which continuously assesses the health of hydraulic hose assemblies in real time, as well as Eaton’s nickel free Guardian Seal technology for protecting metal tube fittings against corrosion. Eaton will also unveil its new PowerSource Web tool, which helps dealers search, specify, and sell Eaton’s full range of products and solutions.
Eaton
www.eaton.com
Filed Under: Hose • wraps + sleeves, Hydraulic equipment + components, Mobile Hydraulic Tips
