Electromagnetic Flowmeter features EtherNet/IP Connectivity
By Design World Staff | December 14, 2011
The Promag 53 electromagnetic flowmeter with EtherNet/IP connectivity integrates with the Rockwell Automation PlantPAx process automation system. The flowmeter measures electrically conductive liquids
Promag-53-electromagnetic-flowmeter
(> 5 µS/cm) for applications in food and beverage, water and wastewater, and other process industries.
The flowmeter features an integrated Web server that allows authorized users to remotely view flow data, conduct diagnostics, configure the flowmeter, or perform process optimization. By using EtherNet/IP, up to 10 variables can be configured, including volume flow, calculated mass flow and totalized flow for remote access.
Traditionally, devices measuring and control-ling process variables rely on a process instrumentation network to transfer data, while other devices within the plant work on a completely different network. By improving this complex multitier networking strategy with one standard network architecture, namely EtherNet/IP, users have better access to real-time information.
The flowmeter has a measuring accuracy is ±0.2% or ±2 millimeters per second, and repeatability is ±0.1% or ± 0.5 mm per second.
Rockwell Automation Inc.
www.rockwellautomation.com
Endress+Hauser Group
www.us.endress.com
Filed Under: Networks • connectivity • fieldbuses
MTConnect Institute releases Version 2.0 of the MTConnect Standard
OPC UA
Everything is moving – OPC UA Companion Specification “Global Positioning”
Single common conformance test plan to be available for the IEC/IEEE 60802 TSN profile for industrial automation
Ethernet/IP Network specification complete for Ethernet-Apl physical layer for process automation
